Visibility problem with styles on mashup
Hi!
I want to restrict visibility for some end users. So I removed "Users" group from 'Everyone' Organization. Than I give visibility for my organization using simple script:
for( var stylename in StyleDefinitions ) {
var params = {
principal: organizationName /* STRING /,</div><div><span class="Apple-tab-span" style="white-space:pre"> </span>principalType: 'Organization' / STRING */
// no return
StyleDefinitions[stylename].AddVisibilityPermission(params);
But still, regular test user see all data, streams etc. on mashup but
there are no colors, no styles visible
. Where is the problem. Did I omit something that visibility permission I should also change?
