I believe this is the config option you are looking for.
sketcher_auto_create_refs
0, 1, 2
0—Does not create the dimensioning references automatically.
1—Automatically adds orientation references as dimensioning references.
2—Automatically creates two dimensioning references.
Setting to 0 should force you to have to pick all your references, every time.
We are on Creo2 M090
Hope this helps...Brian
In Reply to Doug Schaefer:
Creo2 M120
When creating a sketch, Creo will sometimes automatically select a reference plane. Many times that isn't the plane I want to use, so I always go back and check it.
Is there a config option to force Creo to prompt me for a reference plane? I searched the config editor and came up empty.
Brian,
I believe that config option only affects sketcher references, not the orientation reference plane.
Doug,
I don't believe there is a way to force prompting for the orientation reference plane.
David R. Martin II
Senior Mechanical Design Engineer
Amazon
Doug,
It seems that functionality disappeared when they dropped wildfire. We used to be promped for the orientation reference / plane prior to entering the sketcher. I prefer to control the orientation. This "new" way eliminates 1 selection click. Was that PTC thought? I wonder if PTC could enable this "old" method for us old guys who like to discipline their sketches.
funny, that functionality exists when creating external sketches but not extrudes
