How to use get uniform pitch in warp/twist
BHOoi
I have been trying to model a twisted bar with uniform pitch, using warp/twist command. However, no matter what i do, the resulted geometry is always non uniform, as shown below. Any idea how to get an uniform twist? I know this is possible in relational sweep, but i just want to know if  this is possible in warp command. Thanks in advance for the tips.
14 REPLIES 14
John.Pryal
(To:BHOoi)
I think the key to this is your marquee set up. Try using an 'offset' marquee, experiment with the offset values. I am sure if you think about it, that the offset values could be precisely calculated depending upon the height of your initial extrude & the pitch required.
Hope this helps you on your way.
John
Thanks, John. Those settings(offset, absolute ...)are basically meant for start and end of warp  feature, not for pitch....
John.Pryal
(To:BHOoi)
Yes I know this, but by manipulating these offsets you can achieve a more uniform pitch. This might give you what you want depending upon your requirements, it might not.
John
yes... pretty close. What i also wanted was the section orientation at the start and end points coincide so that when I form a ring using toroidal bend the ends match perfectly. Possible?
Patriot_1776
(To:BHOoi)
Actually, it IS uniform....there's just a lead-in and lead-out variation in pitch to make it tangent to the long axis....by design.  If you actually heat up and twist a piece of square bar stock, this is what you'll get.  If you need something else you'll have to construct it via another method.  VSS (Variable Section Sweep) etc.......
I think the warp commands are pretty cool and certainly very powerful....if lacking in the ability to constrain them as we'd like.
hello, Frank. I think you are right, but do you know how do i get rid of those extruded portions ? or.... if i want to trim those away, what is length i should cut?  What I really want is only the helical shape, from start till end so that i can form a ring using Toroidal bend as shown below:
For this simple rectangle section, i could have used VSS instead of warp/twist. However, i am looking at very irregular shapes (such as chain of rings) that are not possible to be created using VSS. I want to explore if I can use warp to facilitate the end creation.
TomD.inPDX
(To:BHOoi)
Warp does a very poor job on joining the ends of a 360 degree bend even if you tweak the marquee.
Never underestimate the power of VSS.  You can drive multiple variations including a weave in a weave.  You can drive it with graphs; algebraic functions, or straight math.  It may be a lot of work, but it can be done.
This is a fully 3D cross using various VSS sweeps...
Spinal bend is a little easier to work with.
Here is the part in the other discussion... trimmed using the known pitch to get a perfect mate on the ends.
Unfortunately, Creo doesn't allow you merge the ends so the seam disappears, no matter what you do!
Patriot_1776
(To:TomD.inPDX)
Nice cross!  You should cast some in a precious metal!
Patriot_1776
(To:BHOoi)
A VSS using trajpar would be perfect for that circle.  You wouldn't need to do a spinal bend on it.
D'uh!  Very true, Frank.
Funny... even in Creo 3, I can twist it 4 times in one feature, but not 3-1/2.  No Mobius here!
Creo 3.0 attached
Patriot_1776
(To:TomD.inPDX)
Knock Knock!
Who's there?
Mobius, that's who!
There's a Pro/WORKAROUND to get the 1/2 twists.....
Okay, give it up and I'll test it in Creo 3.
It worked fine using the spinal bend but not in a VSS going 360 in a single feature.
Patriot_1776
(To:TomD.inPDX)
Yeah, there seems to be a couple limitations in VSS's, one being that you can't do more than 360deg.....supposedly.....
I'll try and e-mail you the file later today and we can discuss!
