asymptote + odesolve
ValeryOchkov
Is there a way to find an asymptote of a function created by the Odesolve function
Thank you.
I think it's a great honour to be named second in place after Christiaan Huygens.
27 REPLIES 27
Hi Valery,
The right-sided asymptote is:
Provided you make sure that F is the point on the y-axis where your focus lies.
In your case F would be -10 (mm).
To get a two-sided asymptote, just replace x with sqrt(x^2).
This plot was made with dimensionless numbers, F= -3, n= sqrt(2).
Thanks, Luc.
Happy NY!
But I think about the red function, not black.
Val
Hi Valery,
The asymptote I gave IS about the y1 function, not the y2....
Note that for the black function, the asymptote goes through (0,-10mm), whereas the y1 asymptote goes through (0,-10/3) for your values of F=1 cm=10 mm and n=2 according to the function I provided: F/ (n+ 1)= -10/ 3.
LucMeekes написал(а):
Hi Valery,
And what is an analytical view of this function?
Ok Valery, here it comes:
Well you know how to solve it numerically, using Odesolve.
I give you the symbolic solution:
An example with F= -1, n=sqrt(2):
To find the asymptote:
Thanks, Luc!
Now I know two man from NL
  1. Christiaan Huygens - Wikipedia
  2. Luc Meekes
Thank you.
Thank you.
About it in my article - http://twt.mpei.ac.ru/ochkov/Mirror-Lens-macket.pdf
And what is the formula for y(x, F, n) at the case not n=sin a/sin b - for n=a/b?
Is this a physical reality?
At little angles! See plots avove!
This is a solution of one DE!
RichardJ
(To:LucMeekes)
Hi Luc
Could you post the worksheet for that?
Thanks.
VladimirN
(To:RichardJ)
I join the request too.
LucMeekes
(To:RichardJ)
Hi Rich,
Here you are.
It's Mathcad 11.     I suspect some things will not work in other versions.
RichardJ
(To:LucMeekes)
Thanks.
You are correct. A lot of the symbolic stuff does not work with the Mupad engine. If I find the time I'll see if I can fix it.
From my future article - sorry - Google translation:
We used two methods for solving optical problems - numerically using Mathcad-function Odesolve and analytical through the site wolfralpha.com. But there is a third (crafty and lazy) way of solving such problems. You can place a problem on the site PTC Community/Mathcad and wait for it someone decides. Thus it was obtained "terrible" formula for y1s (x), placed in the center of the figure 7. It is calculated profile of the focusing lens without changing their angles of the sinuses. This formula (complex analytic solution of a differential equation) led one user Mathcad from Holland - the birthplace of the great Christian Huygens, who made a great contribution to the development of optics - see. https://community.ptc.com/t5/PTC-Mathcad/asymptote-odesolve/td-p/183281. This user Mathcad (Luc Meekes) was the good old 11th version of the engine with a character from the Maple, and not from the MuPAD, which made it possible to solve the problem.
Luc,
The result of the calculation in Mathcad 15 M045 version you can see in the attached PDF file.
LucMeekes
(To:VladimirN)
Thanks.
You can surely understand how happy I am with Mathcad 11.
Thanks.
You can surely understand how happy I am with... Luc and his Mathcad 11.
Val
One partial case of the Luk's formula ( from one Russian optic hand book - https://mipt.ru/dasr/upload/89a/f_3kf3p7-arphh81ii9w.pdf )
One more solution thru a tautochronism
Great, Valery!
I am convinced.
I think it is an errror of numrerical calculation.
The question is.
Is it a one branch of a hyperbola?
The question is.
Yes, hyperbola! One question - why not simplify h*n=h*n
Is any physical in second branch of the hyperbola?
A parabola
A circle
... and a parabola (a mirror)
One simple example
But how can we show that two function y_PC and y_VO are equal? Like sin and tan*cos.
