Mathcad Prime 2 License Server Installation Problem
ssupport
7-Bedrock
Hello, everybody.
I have met some problem when i want to install the Flex License Manager. So, here's the detail of the problem.
  1. The server I want to install the FlexLM to.
    The server is a virtual machine which hosted on a VMWare. The server couldn't connect to the Internet and already have another FlexLM instance which runs at least 5 other licenses. The server only have a network interface (which is the same as the PTC_HOSTID line in the license).
  2. The documentation I've read.
    What I've (which I think relevant to the problem) read was :
    a. Mathcad License Problem - ptc_d daemon is down ... (Couldn't do it. The server doesn't have any PTC product installed yet.)
    b. vendor daemon is not being read...File not found, __PTCD_PATH__ (Already modified the license like that)
    c. Mathcad Prime 2 Installation, License Management section. (Couldn't use the setup file as the server couldn't and shouldn't connected to the internet).
  3. The installer I have.
    Mathcad 14 (don't know if the FlexLM can be installed and read the license for Mathcad Prime 2)
    Mathcad Prime 1, Mathcad Prime 2 (the installer doesn't have the license manager)
  4. The error I got.
Status
Flexible License Manager status on Thu 3/31/2016 13:33
[Detecting lmgrd processes...]
License server status: 27012@VirtualServer
    License file(s) on VirtualServer: E:\Licensing_tools\MathCad\License_files\License.dat:
    VirtualServer: license server UP (MASTER) v10.8
Vendor daemon status (on VirtualServer):
     ptc_d: The desired vendor daemon is down.
Check the lmgrd log file, or try lmreread.
Vendor:Host:   VirtualServer
License path: 27012@VirtualServer;
FlexNet Licensing error:-97,121
For further information, refer to the FlexNet Licensing documentation,
available at "www.flexerasoftware.com".
So, would you mind to help to install the license manager?
Thank you for your help.
VladimirN
(To:ssupport)
1. Send your issue to PTC's tech support by using "Mathcad Support Center":
http://www.ptc.com/support/mathcad_supportCenter.htm
http://blogs.ptc.com/2011/09/22/how-to-use-the-brand-new-online-mathcad-support-center/
2. Try to install license server from the latest Mathcad 15 M045 service release package, here: Thank You for Your Interest in PTC Mathcad 15 | PTC
