FEM calculations on mathcad
vsmikhailov-dis
I'm struggling to calculate moment frame construction using finite element method. Could somebody help me with a useful link to a similar mathcad worksheet?
Sincerely,
Victor
5 REPLIES 5
Search this forum for "finite element"
Also visit here:
http://www.gundermann.dk/mathcad/finelem.htm
There is also an electronic book, "finite element beginnings" that is part of the Mechanical Engineering Library from Mathsoft:
http://webstore.mathsoft.com/dr/v2/ec_Main.Entry17C?SID=7855&SP=10023&CID=0&PID=760511&PN=1&V1=760511&V2=&V3=&V4=&V5=30012754&CUR=840&DSP=&PGRP=0&ABCODE=&CACHE_ID=0
Richard
Victor
Have a look at the beam structural analysis worksheet contained in the DynamAssist Handbook. This can be downloaded from the Mathcad website and I think this may do what you want.
Regards
Ian Ward
Relevant sheet attached.
Regards
Ian Ward
Not applicable
(To:ianward)
Hi Ian,
Can you please tell me what the variables gamma,alpha, Damping C and Delta T are in your Beam example. I pressume "A" and "J" are the area and torsional constant.
Tonymac
ianward
(To:)
Hi Tony
I should have put a bit more explanatory text in the worksheet. You are right about A and J.
If you take a look in the 'Static analysis calculations' area in the worksheet there is a bit more explanation.
The other values you asked about are:
gamma = rotation of element about its own axis(there is a diagram showing this in the User Manual area).
alpha = thermal expansion coefficient
delta T = temperature difference
C = damping coefficient
regards
Ian
