Can I install my software on a new machine if my old one has stopped working?
MarkCheli
Yes though the Creo software is intended for use on single a machine only, if your machine needs to be replaced it is possible to install and license the software on a new machine.
Please submit a Support Request and include:
  • The exact edition of the software you’re using
  • The order number if you purchased the software
  • The product code that you used to install the software the first time
  • The PTC HostID of your machines (this is your physical MAC address of the machine)
A new license file will be sent to you with instructions for installation.
0 REPLIES 0
