Hello All:
I remember that we were able to export a rotatable model to a pdf for others to look at.
Is this something we can do with Creo Elements?
Deguza
Yes, that's correct.
You can do a 3D-pdf, but only with an Acrobat Pro module.
2D- und 3D-Formate (Acrobat 9 Pro Extended, Adobe 3D Reviewer)
Die folgende Tabelle enthält 2D- und 3D-Dateiformate, die Adobe Acrobat 9 Pro Extended und Adobe 3D Reviewer-Software importieren kann. Weitere Hinweise zum Importieren und Exportieren von Dateien finden Sie in der Hilfe von Acrobat 9 Pro Extended und 3D Reviewer.
Format / Anwendung | Erweiterung | Version |
3DXML | 3DXML | Bis 3.0 |
ACIS | SAT, SAB | Bis 15 |
Adobe Acrobat 3D | PDF-Format | 7, 8, 9 |
Autodesk 3D Studio | 3DS | |
Autodesk AutoCAD | DWG, DWF, DXF | 12, 13, 14, 2000-2008 |
Autodesk Inventor | IPT, IAM | Bis 12.x, 2008 |
CATIA Graphical Representation (CGR) | CGR | |
CoCreate OneSpace Designer | PKG, SDP, SDPC, SDW, SDWC, SDA, | V3 bis V2007 |
COLLADA | DAE | |
Dassault CATIA V4 | MODEL, DLV, EXP, SESSION | Bis V4.2.5 |
Dassault CATIA V5 | CATDRAWING | 2D |
Dassault CATIA V5 | CATPRODUCT, CATPART | Bis R18 |
Hewlett-Packard Graphics Library | HP, HGL, HPL, HPGL, PLT | |
Industry Foundation Classes | IFC | IFC2x3 and IFC2x2 |
Initial Graphics Exchange Specification (IGES) | IGS, IGES | 5.1, 5.2, 5.3 |
JTOpen | JT | Bis 8.2 |
KMZ | KMZ | |
Lattice XVL | XV3, XV0 | P-XVL |
PRC | PRC, PRD | Alle Versionen |
Pro/ENGINEER | PRT, XPR, ASM, XAS, NEU | V18.0 bis Wildfire 4 |
PTC CADDS | PD, _PD, CADDS | Versionen 4x/5 explizit |
Siemens I-deas | MF1, ARC, UNV, PKG | Bis 13.x (NX 5) |
Siemens NX | PRT | 2D |
Siemens NX | PRT | Bis NX 5 |
Siemens Parasolid | X_T, X_B | Bis 17 |
Siemens Solid Edge | ASM, PAR, PWD, PSM | V19, V20 |
SolidWorks | SLDASM, SLDPRT | Bis 2009 |
STEP Exchange | STP, STEP | AP 203, AP 214 |
Stereolithography | STL | |
Universal 3D | U3D | ECMA 1, ECMA 3 |
Virtual Reality Modeling Language (VRML) Worlds | WRL, VRML | V1.0, V2.0 |
Wavefront Object | OBJ | Nur Mesh |
Thank you Markus. I don't speak much German but Google translate came to the rescue.
If I understand correctly:
Is what I wrote above correct?
All the best,
Deguza
Arturo,
ProEngineer WildFire 4 added the ability to export a PRT or ASM to a 3D PDF, I bet Creo Elements can do the same, no extra modules required.
File --> Save a Copy... --> Select "PDF U3D (*.pdf)" for "Type"
The 3D PDFs can be viewed with the regular Acrobat Reader:
-Just open the 3D PDF and click on the 2D picture to activate the 3D content
-The user can then rotate, zoom, pan the 3D model and hide/show components
Arturo answer is correct, without extra module you are able to generate a 3D pdf from a model with creo element direct. I did it with the task agent on a big assembly. So as to do that you need the licence option PDF 3D.
After the generation I was able to open the pdf and to see the 3D model, rotate, translate... without any option.
Best regards
Florian,
Do you have licenses for the 3D PDF module? I attempted to turn on the "3D PDF & U3D" Data Interface module in Creo Elements Direct but received an error that "no licenses are available" because we don't have licenses for this. Next I attempted to create a 3D PDF of a part using Task Agent like you said you did but the task failed.
Dan
Hello Daniel,
I had one but now I don't have, you need to contact your PTC sales representative to ask for one.
Best Regards.
Florian
Hello Dan,
You need a "Creo Elements/Direct 3D PDF Converter" license to save a 3D model into a 3D PDF format and Acrobat Reader XI 11.0.3 is able to get it.
As Louis correctly stated, you need a "Creo Elements/Direct 3D PDF Converter" license
The license is also required when you are using Task Agent, since Task Agent starts "CAD" (=Modeling)
for all jobs related to 3D-data.
Talk to your Sales Rep concerning evaluation of 3D PDF - then decide if you want to buy the license.
Max
We have Task Agent licenses but do not have 3D PDF converter licenses. Therefore we are able to create generic CAD formats with Task Agent but no 3D PDFs. Thanks for your responses.
