AFX Customization
ptc-4890515
AFX Customization
Is it possible to add custom profiles to AFX library.
I have found, that many of Bosch MGE profiles are missing in the library.
Jeroen
(To:ptc-4890515)
Ales,
you can find the document here: http://kvisit.com/SnNCDAw
I must say, the document is far from complete, but it might help you getting started.
Jeroen.
6 REPLIES 6
Hi Ales...
Yes, it is possible to add your own custom profiles. If you look carefully, you can find the profiles down inside the AFX directory in your Creo loadpoint. There are some tables and profile sections down in those directories. I had to actually open some of the tables and files up manually to figure out how they worked.
Take a look and see if you can find these. I do not recall the full procedure for how to add new profiles but I know it's possible (and not very hard). If you get stuck, write back and I'll try to take another look.
Thanks!
-Brian
Jeroen
(To:ptc-4890515)
I have a basic manual on that somewhere.
If you are intersted, please let me know.
Jeroen.
Jeroen,
I would really appreciate, if you could share the manual.
It would be much easier to get started.
Thanks!
Ales
Hello Ales,
currently we started to add a bunch more Bosch MGE Profiles to AFX library, if you tell us what you need, maybe we already have it. Send me mail to stefan@buw-soft.de
Stefan
Jeroen
(To:ptc-4890515)
Ales,
Jeroen.
visu
7-Bedrock
(To:Jeroen)
hi Jeroen Bruyndonckx
I have downloaded the zip but i feel little difficult to develop, anyhow we will try it.
If anyone found please share about the downloaded zip file.
Thanks&regards
Viswanathan.K
