Adding a Column to Table
Robert-Altman
Have a user trying to add a column to a table with repeat regions, when
we do the repeat region now spans two columns.
Is there a particular technique where I can add a empty column to the
table? I have tried picking on different places along the edge of the
last column.
Below you can see that the repeat region is spanning two columns
This what I want, a new column that I can now add a repeat region to
The only way we have been able to do it is to delete the region add the
column and then recreate the two regions.
Thanks in advance,
1 REPLY 1
That's the only way I know to do it too.Copy the filter out of the column that's beenadded to so you can paste it back, a small time saver so not to have to recreate that at least after deletingand recreating the region.
