Annotation position move when part dimension change
ckirouac
I am using Creo Parametric Release 11.0 and Datecode11.0.4.0
In reference to Article - CS126394, I don't understand the provided workflow.
3 REPLIES 3
Hi @ckirouac
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Creo looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
kdirth
(To:ckirouac)
CS126394 refers to a possible method to organize MBD annotations.  The solution is that the functionality does not exist in Creo.  Creating a product idea to add this functionality to Creo is the only option at this time.  Creo Parametric Ideas - PTC Community
ckirouac
(To:ckirouac)
I designed a parametric machine that can change in dimension from 8m to 35m. Most of the component are assembly by default position as I use skeleton and copie geometrie to position feature. When I try to use MBD in replacement of drawing, everything seam to work, but when I change machine dimension, annotation seam to keep position from the view and size instead of from geometrie and become far away of the part. It is not possible to read them. I don't want to reposition every annotation eatch time. There is a way to attach dimesions to geometrie?
