Anyone have a list of Pro Engineer Tools & uses?
ptc-5232095
2-Explorer
need to find tools and their uses for my project
3 REPLIES 3
Nick you will need to run a "ptcflush.bat" on the license that your system has aquired. Open a command window and change the directory to "C:\Program Files\ptc\Creo 2.0\Parametric\bin". The batch file is located here.
Next follow this from PTC.
Resolution
  • PTCflush can be used as follows on the client machine
    1. Run the command prompt
    2. Type the command ptcstatus -v to get the License, Feature, Server, Port and Handle of the floating license file to be flushed
    3. Type the ptcflush command with the following syntax ptcflush [feature] [license server] [port] [handle]
  • Example:
  • Ptcstatus -v
Displaying status for license file: C:\Program Files\flexnet\licensing\license.dat
License Server is UP: server0l2 22-66-AA-CC-01-22
ptc_d FLEXnet Publisher version: 10.8License In Use Free Version Expire Date SCN
CREODMA_STANDARD 1 9 33.0 None 1A123456
(user1@clientmachine2) CREODMA_STANDARD server02l 7788 101
  • The [feature] is CREODMA_STANDARD
  • The [license server] is server02l
  • The [port] is 7788
  • The [handle] is 101
  • The ptcflush command would be run as follows: ptcflush CREODMA_STANDARD server02l 7788 101 (Step 3)
Hope this helps!
Nick,
the only reliable method is stop/start license manager service on the server .
ALSO ... You can test license borrowing. If you borrow license, then you don't need permanent access to the license server.
Martin Hanak
Martin Hanák
Martin,
The ptcflush batch file is a reliable method. I have used it many many times over the years and never had any issues. Also, what if Nick does not have access to the license server
Buddy
