need to find tools and their uses for my project
Nick you will need to run a "ptcflush.bat" on the license that your system has aquired. Open a command window and change the directory to "C:\Program Files\ptc\Creo 2.0\Parametric\bin". The batch file is located here.
Next follow this from PTC.
| Resolution |
License Server is UP: server0l2 22-66-AA-CC-01-22ptc_d FLEXnet Publisher version: 10.8License In Use Free Version Expire Date SCN ------- ------ ---- ------- ----------- ----- CREODMA_STANDARD 1 9 33.0 None 1A123456 (user1@clientmachine2) CREODMA_STANDARD server02l 7788 101
Hope this helps!
Nick,
the only reliable method is stop/start license manager service on the server
ALSO ... You can test license borrowing. If you borrow license, then you don't need permanent access to the license server.
Martin Hanak
Martin,
The ptcflush batch file is a reliable method. I have used it many many times over the years and never had any issues. Also, what if Nick does not have access to the license server
Buddy
