Assembly cuts in a part - how to track them down
Dale_Rosema
I have a part that had some holes show up on them. I have track down the errant holes to some assembly cut features.
How do you track down where these assembly cuts were made?
the tree showing the assembly cuts
  two unwanted holes that are the result of the assembly cuts.
Thanks, Dale
Reference viewer not showing them?
Dale_Rosema
(To:dschenken)
This is what I am seeing.
StephenW
(To:Dale_Rosema)
Make the column wider. where the ... is in the parents tells you where the assembly cut is made.
OR right click on the feature and do an INFO.
Dale_Rosema
(To:dschenken)
To the best of my ability, it looks like the cuts were made at this one instance level of the family table of the assembly. I deleted them out of this instance verified the family table and all seems to be in order. Thanks for your help.
Dale,
select assembly cut in model tree of the part, press right mouse button and click Info > Feature. Creo displays information in browser window. In Comments section you will find requested information ... FEATURE WAS CREATED IN ASSEMBLY YourAssembly.
Martin Hanak
Martin Hanák
