I have a dwg. template file set up to add the dimensions to the dwg. views when they are created. However when these dimensions are put on the dwg. they do not reflect the configuration settings that I have for items such as dec. places, nominal tol., etc.. If I add dimensions manually they go in per the configuration settings. When I go into the template file and dimension geometry it reflects my configuration settings as well. Is there a configuration setting somewhere telling the template what to use whe automatically dimensioning the view? This also happens if I do show dimensions within the dwg. veiws.
