BMX and Parameter as a Design Constraint
pdiletti-2
11-Garnet
Hello
using CREO 4 , I'd like to use a Model Parameter as a Design Constraint in BMX module.
In the picture you see, I' d like to replace 100 by a Model parameter (used for other relations as well).
Is it possible ?
Any work-around in case it's not possible ?
Many thanks
Pier
I suggest you to ask PTC Support, too.
Martin Hanák
