Hello ,
The optimization feature in PTC Creo parametric build direction command closes down automatically. Does anybody know the reason for this?
Thank You
Can you please elaborate on the issue reported? Perhaps provide a video, demonstrating the behavior.
Thank you.
The problem is rectified. Thank You.
But however, it would be helpful if you could answer other questions such as,
is it possible to install metal printers in creo?
is it possible to calculate support and build time requirement in creo?
If you could post a reply telling how you rectified your problem, you could then mark it as correct in case some else has this issue.
Also, a new discussion should start a new post because no one will probably see it due to the heading not matching the second question and when/if it is answered, is the correct answer to the first question, or the second.
