CHANGE LINE STYLE ON DIFFERENT SHEETS
MB_10508968
I would like to change styles of the same sketched line used on two different views and on two different sheets.
In the first view, and in the first sheet, I want to use a  yellow "geometry" style line.
In the second view, on second sheet, I would like to use a yellow "phantom" style line.
I've tried to use the "Layout --> Line Style" command: when I change the style of a line on one sheet, it change the style on the other sheet too.
Is there a method to obtain this result?
Thanks a lot.
I tested two independent general views in Creo 7.0. No problem to set two line styles. See video.
Martin Hanák
Hi Martin,
thanks for te answer but I've not two extrusion: I have two sketch to put in sheets.
Best regards,
Michele Barile
@MB_10508968 wrote:
Hi Martin,
Best regards,
Michele Barile
please pack your files into zip file and upload this zip file. I cannot guess what items are included in your drawing.
Martin Hanák
