Can creo do this ? worm/helical gear in UG by mathematical modeling
骁马
all by mathematical modeling
4 REPLIES 4
TomD.inPDX
(To:骁马)
I am going to assume you need the manufacturing extension. We have discussed solid tool material removal along a toolpath in core Creo. The results meant some very extensive operations to achieve proper results.
One has to guess - all computer modeling is mathematical.
I do like the black/dark edges on the parts. Does Creo do that?
When making presentations, it was always, copy Pro/ Engineer screen, paste to Photoshop, select edge color, fill-black.
Inoram
(To:dschenken)
yes
dschenken
(To:Inoram)
I thought I'd seen a report it had. I'll still use Photoshop to select the borders of the model image to increase the line thickness to emphasize the outer boundaries.
