Change imported parasolid units
gshockxcc
7-Bedrock
Still getting familiar with all the settings in Creo.  I have an imported parasolid part that has SI default units, and I'd like to change the default units.  I figured out how to do it for new parts, but I can't figure out how to change the units for imported parts.  I can take measurements, but I would like to export the mass properties in U.S. units.
Is there a way to do this, or do I need to open a new model and import the parasolid into that .prt file?
StephenW
(To:gshockxcc)
You should be able to go to FILE  - Prepare - Model Properties and select Change for the units and then pick your desired units and then SET.
3 REPLIES 3
StephenW
(To:gshockxcc)
That's it!  The one place that I didn't look.  Thanks for the help.
tbraxton
22-Sapphire I
(To:gshockxcc)
Try creating a start part or assembly with the unit system you need first and then import the data.
Create a new model using the start part
Import the parasolid data into this model
This should implement the unit conversion upon importing the file
Involute Development, LLC
Consulting Engineers
