Change pdf size on export
EricHuffman
2-Explorer
Gurus,
What is the quickest/easiest way to export/save an E-Size CREO drawing to an A-Size pdf?
CREO 2.0 m110
Windchill 10.0 m030
Eric
6 REPLIES 6
ploney
(To:EricHuffman)
File, Save a Copy, Select PDF from the file type pull down.
TomU
(To:EricHuffman)
You cannot change the sheet size of a PDF on export.
Why would you want to?
We do all our pdf's at full size and choose the paper size in Acrobat. That way the line weights get scaled down appropriately also.
David Haigh
TomU
(To:EricHuffman)
Instead you could set up Ghostscript, output a postscript file, and then tell Ghostscript you want all files converted to A size. If you really wanted to you could even configure it like a printer where everything you print to it automatically gets converted to an A size PDF.
Tom U.
I think I've done such a thing with printing to CutePDF... As opposed to saving... I don't have a system handy to check. CutePDF is a PDF creating software that installs and pretends to be a printer. So you print out of CREO, into MS PRINT MANAGER, then select CutePDF as your printer and adjust the options there...
ploney
(To:EricHuffman)
I mistook your request earlier for plain printing to PDF, my bad.
I can confirm What David stated, cutePDF installed as a windows printer
will allow you to Set the Output Size(In Creo) to A regardless of the
actual size in Creo.
