Doug,
You are correct. The approximate curve removes your ability to specify a tangency condition across the surface boundary. However, if you have the ability to redefine your older surface to use the new approximate curve...you are laughing. I use this technique often when I need to get the surface "sweet" and correct.
Secondly, just food for thought. In order to have the ability to specify the tangency across the boundary using exact curves, your vertices should be coincident for both surfaces. I have had very limited "random" situations where I was able to specify C1, with the "pieces" not lining up explicitly. but that was a case of being lucky, not good.
Dean
