Compound Sketch
Mar 20, 2012
10:46 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Mar 20, 2012
10:46 AM
Compound Sketch
I created a compound Sketch (2 separate sketches)and now I would like to create a radius between the two. Is this possible?
Basically I'm trying to recreate a cable/pipe from an old drawing using the dimensions provided.
Thanks.
-Art
WF4
[cid:image001.png@01CD066D.3CBFFF30]
[cid:image002.png@01CD066D.8959AD50]
This message (including any attachments) contains
confidential and/or proprietary information intended
only for the addressee. Any unauthorized disclosure,
copying, distribution or reliance on the contents of this
information is strictly prohibited and may constitute a violation
of law. If you are not the intended recipient, please notify the
sender immediately by responding to this e-mail, and delete the
message from your system. If you have any questions about this
e-mail please notify the sender immediately.
Thanks.
-Art
WF4
Labels:
- Labels:
Routed Syst. Design
Mar 20, 2012
11:06 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Mar 20, 2012
11:06 AM
Mar 20, 2012
01:27 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Mar 20, 2012
01:27 PM
just make your 90 degree corner one separate sketch with the radiius.
ref the ends from your other sketches.
Gary Miglionico
Mar 20, 2012
10:20 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Mar 20, 2012
10:20 PM
Hi Art,
You could also do it by adding a Datum curve through points to make that
radius (or near equivalent).
You would add Datum Points onto each of the original curves by:
- Copy (Exact or Approximate) the two original curves and trim at those
new points (hide the original curves to make things easier).
- make a Datum curve Through Points from those newly trimmed ends of
those copied curves and set the tangency onto the adjacent curves.
- finally Copy (Exact or Approximate) these three curves to make them
one. Guarantees you will get a sweep-able curve for your cable.
Hope this helps.
*Brent Drysdale*
*Senior Design Engineer*
Tait Communications
Hope this helps.
*Brent Drysdale*
Tait Communications
