Assembly of Family Table
  • March 21, 2012
  • 0 replies
  • 492 views
Gurus,
Please disregard my earlier post.
See attached. In my family table of an assembly I created two instances, "A" & "B", with either sleve "A" or "B" respectively. The B-surface is related to sleeve "A" and so is the mate assembly reference of the Back End Cap. Instance "A" works fine. However in instance "B" both the surface and Back end capare removed due to sleeve "A" is replaced by sleeve "B". What is the correct procedure to assemble the Back End Cap. I could do it with dimensions, but I really want it to mate with the end of either sleeve "A" or "B".
I think I need to make a generic of the sleeve then assemble this into my generic assembly.
Using WF4
