I want to make a note display certain text depending on a dimension of a part. I'm guessing it is a basic if statement somewhere, I just don't know where to put it.
Ex:
if d1:0 = .375
"display this text in a note"
endif
You put it in the relations. The relations then creates a parameter which you call out on the drawing with &NOTE
IF d0 == .375
NOTE = "YEAH IT WORKS"
ELSE
NOTE = "NOPE IT DOESN'T"
ENDIF
IF d0 == .375
ELSE
ENDIF
That worked, thank you!
