Conditional note from dimension
cbell-3
I want to make a note display certain text depending on a dimension of a part. I'm guessing it is a basic if statement somewhere, I just don't know where to put it.
Ex:
if d1:0 = .375
     "display this text in a note"
endif
Chris3
(To:cbell-3)
You put it in the relations. The relations then creates a parameter which you call out on the drawing with &NOTE
IF d0 == .375
     NOTE = "YEAH IT WORKS"
ELSE
     NOTE = "NOPE IT DOESN'T"
ENDIF
2 REPLIES 2
Chris3
(To:cbell-3)
IF d0 == .375
ELSE
ENDIF
cbell-3
(To:Chris3)
That worked, thank you!
