Cosmetic Sketch Hatching
ToddMalenke
I am running WF4.0 M80..
Has anyone run into an issue of creating a Cosmetic Sketch ( with Hatching )
on a Part, BUT the hatch will not show up on the drawing?... the boundary of
the sketch will show and the hatching temporarily highlights as you pass
your cursor over it, but the hatch will not display or print.
In this case, I am using this to simply highlight an area of a part to
depict a special paint requirement. But have used this for special GDT
requirements as well ( older pro/E version ).
My work-around was to use draft entity hatch that area, but it is bugging me
to no end, it SHOULD work with a cosmetic sketch.
Todd Malenke - Design Engineering
Machining & Welding by Olsen, Inc.
250 Olsen Blvd, POBox 970, Cokato, MN 55321
952-516-7655 - Direct
320-286-2187 - Phone
320-286-2962 - Fax
Bari
(To:ToddMalenke)
It's a problem with M080 datecode. Just update to datecode M090 or above.
