I am very new to Creo Schematics and the Creo 4.0 Harness tool.
Although I have completed the basic tutorial, I still have several problems, I hope you can help me with:
1. I have trouble with my connectors in Creo Parametric. I know that I have to create a coordinate system an make the y-axis point towards the cable, so that is is considered as a pin. I still get the error, that there are missing information for the cables. Is there anything I forgot?
2. I do not manage to create my own cable and wire datasheets. I know that I need a .csv file, but I failed to create it correctly and to import it into schematics.
I hope you can help me or tell me where I can get help
Actually, the Z axis needs to point in the direction of routing. What is the error that you get about missing information? Is it from trying to route using XML data from Creo Schematics or manual routing?
Here's a video I made about setting up connectors for routing:
thank you for the response and the great video. I actually managed to create a connector and auto route wires to it with XML data.
Unfortuanately I still do not know how to splice wires and create own cables. Do you also know how this is made (in Schematics)?
