Create model parameter from Model check report
ssharma-6
2-Explorer
I want to create a parameter for overall size of the parts and I know that value of overall size can be seen in Modelcheck report (with setting in MC configurator).
However I don't know how to link Modelcheck report values to the model parameters, there must be some setting within Modelcheck configurator but I am unable to find it.
Please help !
4 REPLIES 4
huggre
(To:ssharma-6)
Search for ADD_CHK_PARAM in the Modelcheck user guide.
This will allow you to create a parameter that stores the outcome of another check.
(Not sure if it woks for model size, havent tested it)
In my company we capture the outer x/y/z dimensions of a part by referencing exisiting model dimensions in a set of relations that writes the result to a designated string parameter.
You can also use a note parameter to do the same, however, as far as i know, note parameters can not be designated if that is a requirement.
jforsyth
(To:huggre)
Where can I find the Modelcheck Users Guide?
llie
(To:jforsyth)
jforsyth
(To:llie)
That worked.
