I am trying to create a 3D dxf file of an assembly in Creo 10. I also have an assembly level drawing of the entire model. Is it possible to create a 3D .dxf file or .dwg file?
DXF and DWG aren't particularly good choices when it comes to 3D models exported from Creo. As far as I know, it will only send them out as tesselated models. I tested on Creo 6 and also on Creo + (aka Creo 12) and the result was pretty much the same.
You can export an assembly drawing also. They open ok. After export, there is no connection from the exported model to the export assembly.
