Is there a way to create a Spatial zone in a assembly then create a shrinkwrap of that zone? Or a Envelope of zone? The assembly I have I cant do extrude cuts in the model to delete what i need from assembly because the geometry was brought in as external copy geometry and solidified. I don't want to send the entire assembly off to supplier just a zone of the assembly.
generally, you can use simplified representation to include the parts you need to send to the supplier, and then you do a shrinkwrap of this particular assembly.
hope it is what you want.
claude
