Creating custom settings for hole dimensioning in creo 2D Drawing.in creo 4
hvyas-2
7-Bedrock
Hi Team,
I want to keep custom settings in Creo in such a way that whenever I create a hole in the model.
The Hole location and it's depth dimensioning should have 2 decimal places by default in the drawing.
Also, I want to set The angle of the hole as basic by default.
Is there any possibility without affecting other things' tolerance in 2D Drawing?
 The rest of the dimensioning should be per Creo default.
I would appreciate any solution for the above request. Thanks so much in Advance.
5 REPLIES 5
I fear that you are not in the correct community. Here you are in the community "Creo Elements Direct" that is a software different from Creo Parametric. You should move your post to the community "Creo Parametric" to have a better chance to get an answer.
PTC has two CAD systems:    Creo Parametric    and     Creo Elements Direct.
Which makes it confusing. You are not the first, not far from the millionth mistaking who will win a prize.
More, for Creo Elements Direct:
- The 3D software name is Modeling, and
- The 2D software name is Drafting.
For Creo Parametric, use only this tab:
http://kotom.eng.free.fr
Thanks for informing. How can I delete this question? here?
Not necessary. Just ask the moderator to move this post to the right place.
IbrahimTayyab
(To:Kotom-Eng)
I have come from the Creo parametric community, may I enquire what the prize for the millionth will be?
          1.5 Kudos
