Is it possible to make 2D or 3D pdf file by using Pro/ENGINEER. Actually i want to convert Pro/DRAFTING(*.drw) file to PDF(*.pdf) file. This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
Open drw file-save as copy-from pull down menu -choose pdf.Make a separate working directory-or folder to save pdf.Before saving pdf choose your working directory, then you can keep all pdf copies separate
Hello Anand, what pro/e version are you using? Wf3.0 - 64 Bits does not allow to create pdf. WF 3.0 32 Bits, should do it easily, it has and pdf export module embedded as default.
open the 3d part file < print Pint window pops up next to Destination attributes there is plus sign w/black arrow (+) click on it then it will expand the table select Generic color postscript Mark the To File option and unmark the To Printer option Hit OK Another window pops up with title Print the File. Keep the default selection mark which will be Create Single File. Next to Name there is browse button. Click on it and locate the path where you want to save your file. Once you hit ok.It will create the file with .PS extension.Select the .PS extension file and change into PDF. Done.
