Creo 1.0 site issues
BillChapman
We are having intermittent issues with Pro NC not transferring the site file setting into nc sequences. It will work OK for one operation and then stop working on the next. Started after going to Creo 1.0. We are running Win7 64.
The site is always defined and active, the parameters are just not getting into the nc sequences consistently.
Any suggestions, or just a bug PTC needs to work out?
Bill Chapman
Sencon
Bill,
We are having the same issue with Creo 1.0 M030 (Win7 64), no solution
yet.
Barry
I've seen the same problem here... but had no time to report or
reproduce it yet... it's seems to be intermittent...
Also, if you are creating toolpaths using process manager, the
visibility settings are not respected. It is a confirmed bug - SPR
#2111748
Win 7 64 here too, but I've this in Win 7 32 and XP both architectures
too...
I hope someone could report it to PTC,
Best
Daniel
By the way:
WF5 M120 here....
