Creo 10 -- printing centerlines -- proper scale
steved
3-Newcomer
I'm trying to get centerlines to print properly, either on paper or PDF.  My DRW is shown in 1st pic.  The centerlines are adjusted so that each hole has the small dashes in the center.  The 2nd pic is what the PDF output looks like -- small dashes are gone.  I found plot_linestyle_scale setting, which does exactly what I'm looking for, but for the DOTFONT line style (hidden lines).  Anybody know how to similarly adjust scaling factor for CTRLFONT line style?
MartinHanak
(To:steved)
it would be helpful to upload testing data.
Martin Hanák
Thank you for the response Martin.  I am trying to attach the relevant files (PRT, DRW, PDF), but I'm getting this error message:
Correct the highlighted errors and try again.
  • The attachment's ft-37653.prt content type (application/octet-stream) does not match its file extension and has been removed.
Steve Drake
MartinHanak
(To:steved)
Steve Drake
please pack all files into single zip file and upload this file.
Martin Hanák
