Creo 2.0 trail file
NitMad
Creo 2.0 trail file
I have tail file for generating PDFs of multiple drawings in a location.
A part of the tail file is as follows:
~ Command `ProCmdEnvDtmDisp`  0
!%CIDatum planes will not be displayed.
~ Command `ProCmdEnvAxisDisp`  0
!%CIAxes will not be displayed.
~ Command `ProCmdEnvPntsDisp`  0
!%CIDatum points will not be displayed.
~ Command `ProCmdEnvCsysDisp`  0
!%CICoordinate Systems will not be displayed.
~ Wheel `main_dlg_cur` `proe_win` 9 553 200 393216 1024 1455 806 1920 1080 142438
~ Wheel `main_dlg_cur` `proe_win` 9 553 200 393216 0 1455 806 1920 1080 142703
~ Command `ProCmdViewRefit`
~ Close `main_dlg_cur` `appl_casc`
~ Command `ProCmdModelSaveAs`
~ Open `file_saveas` `type_option`
~ Close `file_saveas` `type_option`
~ Select `file_saveas` `type_option` 1 `db_617`
~ Activate `file_saveas` `OK`
~ Open `intf_profile` `pdf_export.pdf_raster_dpi`
~ Close `intf_profile` `pdf_export.pdf_raster_dpi`
~ Select `intf_profile` `pdf_export.pdf_raster_dpi` 1 `600`
~ Select `intf_profile` `pdf_export.pdf_color_depth` 1 `pdf_mono`
~ Select `intf_profile` `pdf_export.PDFMainTab` 1 `pdf_export.PDFContent`
~ Select `intf_profile` `pdf_export.pdf_layers_opt` 1 `pdf_layers_none`
~ Select `intf_profile` `pdf_export.pdf_font_stroke` 1 `pdf_stroke_all`
~ Activate `intf_profile` `OkPshBtn`
The problem is that, even when the datums are turned off they show up in some drawings and do not i a few others. What might be the reason? I am still new to this and figuring out stuff by going through the trail file after performing certain actions.
Thank You
NitMad
(To:epxkle)
4 REPLIES 4
Jose_Costa
(To:NitMad)
This seems to work in Creo 3:
~ Activate `main_dlg_cur` `igToolbar_AncestorIGT_IGT_GRP_inh407412841.proe_win|.mcs29658718_mp|select_a\
ll_check` 0
~ Activate `main_dlg_cur` `main_dlg_cur`
~ Activate `UI Message Dialog` `UI Message Dialog`
~ Activate `UI Message Dialog` `ok`
Use the "select all" datums instead and should work ok.
José
José,
Thank you for the reply.
Wouldn't it toggle the status every time?
I will try it.
I created a config file with all the datum display set to no and included the command to open the config file each time i need to create a PDF.
Nithish
epxkle
(To:NitMad)
hi,it's easy, u need config file, and placed in the startup directory. aa.pngTIM图片20180120103255.png
 and, you'd better set some maykeys for this datum.
NitMad
(To:epxkle)
