I believe this is a bug. My coworker gets the same result. In a drawing, when trying to translate or copy something along a line (by picking two points on the line) it doesn't work.
To simplify, here are steps to reproduce:
It works for a point on one line to a point on a different line. All the other selections (vertex, free point, etc) work as expected. It's only from a point on a line to another point on the SAME line that doesn't work.
Carolyn,
you can ask PTC to check & resolve the problem. Open Case at PTC ... https://www.ptc.com/appserver/cs/case/case_logger.jsp
Martin Hanak
