List of Creo 3.0 M010 configuration options.
Hope it can help...
Thanks Milan for the info,
Vladimir
Isn't there some kind of list that tells you what has changed and what's been added?
Olaf's site has that.
Config File http://proesite.com/UTIL/compare_creo3_creo2_allopt.html
Detail Setup File http://proesite.com/UTIL/compare_creo3_creo2_allsetup.html
Great!! Thanks
If you look at the Table of Contents of that document it tells you the changes.
Creo 2.0 to PTC Creo 3.0 Parametric Configuration Options Changes
