Creo 3.0 tryout file wont open in activ version
Farogid
Hello, i have a problem. I was working in trial version of creo 3.0, and i have made sketches a lot, and when i try to open them in a activ creo 3.0 i couldnt open them because it sad it wasnt compatible. Please can someone help me? Is there any way to open them?
I'd say you're out of luck 😞
The best solution is to recreate your data with Creo using Commercial license.
Martin Hanák
Farogid
(To:MartinHanak)
I thought that, thank you for the reply.
StephenW
(To:Farogid)
If you were using the trial version and then you bought the license for the full version, PTC may help you convert the files.  If you did, contact your PTC sales representative.
