Does anyone know if Creo 8 or 11 will display higher than 1080p. We are getting new offices and are trying to decide on new monitors. Does anyone know if 1440p is worth it from experience when you mainly use Creo?
Thanks in advance,
Lex
I run Creo 4, 7 , & 9 on QHD monitors without any issues. I know of others running using 4K displays.
my colleagues use 40 inch displays with 4K resolution.
