While working in Creo, I see that the “view change” window opens every time in the assembly parts we open in the Windchill system, which I share as a screenshot below. Although I have corrected the errors in the system, this screen appears every time I open the assembly file in Creo. Actually, I found the solution to the problem, but I want to know what the root cause of the error is. In which error situation this screen appears. Can anyone write if they have information about this subject?
Hi @fatihsimsek,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
