6-Contributor
October 21, 2024
Creo 8 / flat harness / create a flat harness with several independent wires
  • October 21, 2024
  • 679 views
Hello, is it possible to create a flat harness with wires that are not in direct contact?
As in picture 1, it is composed of separate wire. the problem is when I decide a start point, I can not go and look for another point on a non-attached wire.
I would like to know if it is possible to do everything in one flat harness or if it is necessary to separate each wire that does not touch into different harnesses?
Community Moderator
October 28, 2024
Hi @TM_10264935,
Thank you for your question.
 Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
