Creo View: Rotate view about X/Y/Z axis
VeqTor
Hi forum,
how can I rotate a view about one of the three axes X/Y/Z?
Note that I don't want to "transform" a part.
I just want to rotate the entire view, as you normally do using the middle mouse button.
2 REPLIES 2
MartinHanak
(To:VeqTor)
I did not find any usable setting in Creo View Express.
My workaround:
  • select top assembly in model tree
  • press F3 to invoke Transform command
  • rotate assembly
  • at the end press CTRL+SHIFT+R to invoke Restore All to Original command
Martin Hanák
VeqTor
(To:MartinHanak)
Thank you Martin for this workaround!
I just realized that, however only in Creo View MCAD, you can create custom "Orientations" that sort of allow rotating the view about any of the X/Y/Z axis.
