Hallo,
when I open a CAD assembly model in Creo View, it never shows up in the graphing area and I see only white, therefore I have to tick on the tree on the left bar in order to show the assembly and/or its components.
Ho can I set by default the option to see everything immediately at start up?
thanks
Tommaso
Tomasso,
click File > Options > General > Loading > Load Creo View data as: Autoload all file
This setting is saved in %APPDATA%\ptc\ProductView\user_prefs.xml file.
Martin Hanak
Tomasso,
Martin Hanak
Hi Martin,
thanks a lot.
(I don't see the button "correct reply" anymore...)
Bye
Hello Tommaso,
The thread / discussion was not marked as a question - that is why the button was not available.
I marked it as discussion now and Martin's post as Correct Answer (assuming this was what you had in mind)
Gunter
