Creo can't save pkg files
dwooldridge
I get this error when I try to save a pkg file. This is my first time using Creo 4.0 and I need to save files for a class.
Creo Elements/Direct Modeling could not create the package file "H:/ghn.pk2". Please check if you have sufficient virtual memory, and if you have left enough space in the destination directory and in "C:/Users/WOOLDR~1/AppData/Local/Temp/3dv0q4841n6maq87296.autotmp".   (Error -1)
4 REPLIES 4
Creo 4.0 and Files .PK2?
IMHO .PK2 is created by CED Modeling Express
Also, please check if you have write permission on the H:  drive, since this seems to be the destination for your .PK2 file.
I am using Creo Elements Direct Modeling Express 4.0 (English). Yes, I am writing to my H drive but I can put other stuff on it.
I went to C:\Users\wooldridgedc\AppData\Local\Temp and 3dv0q4841n6maq87296.autotmp was not there.
Saving your data first goes to %TEMP% and then it is moved/copied to the H: drive
Try Setting Environment variable TEMP (%TEMP%) to a Location on your H: drive.
Also, you are using a pretty old Version of Modeling Express.
The current Version is 6.0 - you should give that a try.
btw.on which platform are you running Express 4.0?
