Creo taking ifx_translation file from Default location , not custom library location
Vinayak_Patil
11-Garnet
I am trying to create my custom ifx library, I have setup all parts, their catalogs and other configuration.
I have also created translation file for catalogs names and their helptext.
I have used runtime variable creation process to use custom library location.
Creo parametric is taking all components and configs from custom location but it is not taking translation file from my custom location. It is using ifx_translation file from default creo installation.
Is their any settings/config need to add , please help a=uf anyone knows.
you can use the ifx_translation for group and helptext as well.
Look at '#screws din_fastener' for an example.
Oliver Gräbner
B&W Software GmbH
11 REPLIES 11
you cannot use a custom setup for the ifx_translation.txt files. This is not possible right now.
IFX use the translation mechanism from Creo - this is why the translation is always be loaded from the creo/ifx installation folder.
We have an enhancement request to move the translation files to the ifx 'parts' folder and load it from there, but this is not available yet.
How many languages to you have?
Oliver Gräbner
B&W Software GmbH
Hi, we have 2 languages and we want to show catalogue group name in two language using help text option from translation files.
For subcomponents I think we can use Subinfo option.
Can we use same for catalogue groups ?
Oliver Gräbner
B&W Software GmbH
Hi, Thank you for your response. I think for now I should not use the translation file as it is not useful with a custom library.
@Vinayak_Patil @TommyW
Thank you for your feedback and sorry for the late reply.
What do you think would be better.
  • Having the translation directly inside the *.dat file
  • Use one translation file with message ids link <dat>.Label or <catalog>.HelpText
  • Use a combination of both
Inside *.dat
Enter the translation directly to the *.dat file
LABEL             My Screw
LABEL.german      Meine Schraube
LABEL.<LANG>      <custom label translation>
HELPTEXT          Special Screw
HELPTEXT.german   Spezial Schraube
HELPTEXT.<LANG>   <custom helptext translation>
Translation file
Have a file (ifx_translation.txt) with translation inside the parts language subfolders:
 parts
 - ifx_fastener_data
   - german
   - french
 - ifx_catalogs
   - german
   - french
Combination of both
Use a tag-id inside your *.dat file like hexagon_screw_txt
have one translaton file for each language with tag-id and translation.
So what do you think would be the best solution.
Or do you have any other ideas?
Oliver Gräbner
B&W Software GmbH
HI, Translation file will be better for Language management. But it should be part of Custom library. Because custom library rollout is easy than set to default locations.
thanks for feedback.
We will verify if this is a good enhancement for the next releases.
Oliver Gräbner
B&W Software GmbH
TommyW
(To:OliverGräbner)
Hello Oliver
At Xylem WS we would like that very much, please. I would be extremely helpful...
Tommy Weinberg
Xylem Water Solutions
Is there any concrete information on which Creo version this improvement will be implemented in?
We would also like to roll out a user-defined IFX library (using the environment variable IFX_USER_CONFIG_PATH).
However, I see it as a major drawback to have to maintain the translation files in the Creo installation directory.
You have to remember to copy this file with every small Creo update (e.g. v10.0.8.9 to v10.0.9.0). And with the few thousand Creo users in our company, this can become a challenge.
We will add this in these Creo Parametric versions:
  • 10.0.11.0
  • 11.0.8.0
  • 12.4.3.0
  • 13.2.0.0
If inside the folder from IFX option 'PATH_ABS_LIBRARY' a file 'text/<language>/ifx_translation.txt' exists, the translation will be taken from there.
If file not exists, the 'ifx/text' folder inside the creo-installation will be used.
File content from 'ifx_translation.txt' will be the same as before. So you only have to copy/move your files to the new subfolder.
By default we will keep the file inside the creo-installation.
Hope this will solve your requirements.
Oliver Gräbner
B&W Software GmbH
Hi @Vinayak_Patil,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
