DATE FORMAT
jcolon
9-Granite
DATE FORMAT
On our borders we used to have (In Creo 2.0) the format set to DD-MM-YY, but now in Creo 3.0 it switched around to MM-DD-YY. Is there a way to change this format so that it is DD-MM-YY or even DD-MM-YYYY?
TomU
(To:jcolon)
It depends on whether this value is coming from Windchill or from the &todays_date note.  One of these two config options should take care of the issue:
  • date_type_parameter_format %yyyy-%mm-%dd
  • todays_date_note_format %mm-%dd-%yy
Both can be adjusted to the syntax you want.
3 REPLIES 3
Hello Javier, I think it  based on your system date format, Check your system date time settings
Parthiban Kannan
href="https://www.linkedin.com/in/parthiban-kannan/" target="_blank"
TomU
(To:jcolon)
jcolon
9-Granite
(To:TomU)
It was the todays_date_note_format... weird thing is that it was already set to %mm-%dd-%yy, but setting it to %dd-%mm-%yy achieved the desired effect.
We have no idea what is the underlying issue since the upgrade, but atleast now it is fixed.
Thanks!
