DRW to PDF in batch
prajan
DRW to PDF in batch
Hi,  Anyone suggest me a way to save all drawings in a folder to save as pdf.
If i have 20 Drawings in a folder in 'drw' format. How can i save all drawings to pdf in batch.
9 REPLIES 9
dnordin
(To:prajan)
Use ptcdbatch.bat (PTC Distributed Batch) assuming it was included as part of your Creo installation .  It's located in the parametric\bin directory.
Dan N.
Hi Pradeep,
You can use the PDF DRW Single Page Export or PDF DRW Multi Page Export ttd file, within Creo Distributed Batch.
Amit
prajan
(To:prajan)
Hi Daniel/Amit,
Thanks.
Used ptcdbatch.bat and able to generate pdfs in batch. But the generated pdf contains Planes and axis. How to control it, How can i hide axis and planes in generated pdf. Please suggest.
Thanks in Advance.
prajan
(To:prajan)
Hi Daniel/ Amit. Thanx for the info.. Used ptcdbatch.bat (PTC DSITRIBUTED BATCH) and able to generate PDFs in batch.
But, Generated PDFs contains axis and planes. How can I control it and generate a PDF as same as printed pdf.
Please suggest.
Thanx in Advance.
RaphMORIN
(To:prajan)
I think I can remember you can specify a config.pro file to get the same setup as if you were in Creo.
prajan
(To:prajan)
Thanks Morin, I got it now !!
prajan
(To:prajan)
I used "PDF DRAW Multipage Export Visible" along with my config.pro. But the tasks submitted in Creo Distributed Batch are getting Failed. Please help me.!!
RaphMORIN
(To:prajan)
I tried also to set up Creo Distributed Batch a while ago, but never managed to avoid these errors. It seems to happen randomly. At this time I opened a case on support, but it was never solved. And finally, I found it quicker to export my drawings one by one directly in Creo.
hi,
i fix my problems by setting the creo distributed batch like this:
i copied the plot_drw_single_pg_to_pdf.ttd in my config directory, changing its name.to plot_drw_single_pg_to_pdf_lap.ttd
and i modify some things.
Like getting monochrome print instead of colors
<color enum="PRO_PDF_CD_MONO"/>
or cad fonts instead of true type for example
<font enum="PRO_PDF_STROKE_ALL_FONTS"/>
exporting all sheets instead of a single one
<sheets enum="PRINT_ALL_SHEETS"/>
(in the end of post the complete ttd xml file)
then i create a distributed batch pointing to that file
dsm indemendent
in the configuration file i added just my config.pro that have inside all information about colors plotter and pen table.
it works. some time i have to run the task and manually select the objects, right click and send them again.
<?xml version="1.0" encoding="UTF-8"?>
<!-- 25-Jan-07 L-01-25 TWH $$1 Submitted -->
<!-- 05-May-08 L-03-08 TWH $$2 Chg DESC, DETAILS -->
<!-- 14-Jan-11 L-05-40 TWH $$3 Rebrading -->
<!-- 17-Feb-15 P-30-03 mtch $$4 Added group -->
<!-- 03-Sep-15 P-30-16 mtch $$5 Added FILTER_FILE_TYPES -->
<!-- 06-Nov-17 P-50-35 EOR $$6 Change range to selected single sheet. -->
<TTD version="1.0" created_by="PTC">
<DESCRIPTION>PDF Export</DESCRIPTION>
<GROUP>Plot</GROUP>
<DETAILS>Create PDF file of all sheets from Creo Pro drawing file</DETAILS>
<SERVICE name="dbatchs"/>
<FILTER_FILE_TYPES type=".drw"/>
<TKFUNC func="ProPDFExport">
<TKSTRUCT struct="ProPdfOptions">
<hlr enum="PRO_PDF_HLM_DASHED"/>
<layers enum="PRO_PDF_LAYERS_VISIBLE"/>
<parameters enum="PRO_PDF_PARAMS_ALL"/>
<!-- use "selected" to export single sheet or
"min" and "max to export multiple sheets in a range" -->
<!-- sheets enum="PRINT_CURRENT_SHEET" -->
<searchable_text>true</searchable_text>
<dpi>300</dpi>
<hyperlinks>true</hyperlinks>
<bookmark_zones>true</bookmark_zones>
<bookmark_views>true</bookmark_views>
<bookmark_sheets>true</bookmark_sheets>
<bookmark_flagnotes>true</bookmark_flagnotes>
<title></title>
<author></author>
<subject></subject>
<keywords></keywords>
<open_password></open_password>
<master_password></master_password>
<allow_printing enum="PRO_PDF_PRINTING_HIGH_RES">true</allow_printing>
<restrict enum="PRO_PDF_RESTRICT_NONE"/>
<allow_copying>true</allow_copying>
<allow_accessibility>true</allow_accessibility>
</TKSTRUCT>
</TKFUNC>
</TTD>
