In NX there is a option as 'Enforce Piece Part'. By this option it will not be possible to add any other part/component so that resulting part will be only piece part, not an assembly part.
Is there any similar option/preference available in Creo?
NX is a different architecture than Creo.
NX allows multi-body parts, Creo does not.
NX uses a single file extension (.prt), Creo uses multiple extensions (.prt, asm, .drw, etc.).
There is no need for this option in Creo.
18 years using UGII/NX, 18 years using Pro/E/Wildfire/Creo.
No. Creo does not support multi-body parts so this concept is not valid.
Hi @StephenW,
Thanks for the reply. I have attached a short NX video as a example.
I won't download a video due to security issues.
Creo does not allow multiple parts in a part.
No, you can only mark one as the solution.
I would mark Ben's as the solution since it is the most clear explanation.
