A designated parameter will only transfer to Windchill if a corresponding attribute with the same name is defined in Windchill first. Yes, the parameters must be designated to transfer. If a parameter is not designated, the value will not be visible in Windchill. If a parameter is designated in Creo but undefined in Windchill, a warning will be thrown during upload, but you won't be prevented from checking in. Again, the value will not be visible in Windchill.
Here are directions on how to configure this mapping:
